You can disable EAPoL authentication for specific Fabric Attach (FA) client types.
By default, authentication is required before the connection is authorized.
    enable
    configure terminal
  2. Configure EAPoL authentication requirements from the following choices:
    • For auto-sensed cameras: auto-sense fa camera eapol status {authorized | auto}
    • For auto-sensed virtual switches: auto-sense fa ovs eapol status {authorized | auto}
    • For auto-sensed wireless access points (WAP): auto-sense fa wap-type1 eapol status {authorized | auto}
The following table defines parameters for the auto-sense commands related to EAPoL authentication for Fabric Attach (FA).
Variable
Value
{authorized | auto}
Configures the EAPoL authentication requirement for the specific client type. Choose from the following options:
  • authorized — the port skips EAPoL authentication and authorizes the connection.
  • auto — authorization depends on the result of EAPoL authentication.
